File save no file date change in windows explorer
3 REPLIES 3
1568 Views, 3 Replies
I saved a project but the date of the file did not change in windows explorer?
(1) This file is not a part of a central file
(2) saved and exited revit.
(3) closed and restarted windows explorer
(4) did a search of c drive for todays date and found file listed that I had save with correct date in this window, but in the actual folder date is wrong.
(5) opened the file and it was saved with latest changes.
It fine since it did save, but I sometimes rely on the date to locate files. Anyone ever heard of this bug? See attach jpegs and you can see it is the same folder.
my system specs:
OS Name Microsoft Windows 7 Professional
Version 6.1.7601 Service Pack 1 Build 7601
Other OS Description Not Available
System Manufacturer INTEL_
System Model DX58SO2_
System Type x64-based PC
Processor Intel(R) Core(TM) i7 CPU X 990 @ 3.47GHz, 3459 Mhz, 6 Core(s), 12 Logical Processor(s)
BIOS Version/Date Intel Corp. SOX5820J.86A.0603.2010.1117.1506, 11/17/2010
SMBIOS Version 2.5
Windows Directory C:\Windows
System Directory C:\Windows\system32
Boot Device \Device\HarddiskVolume4
Locale United States
Hardware Abstraction Layer Version = "6.1.7601.17514"
Installed Physical Memory (RAM) 12.0 GB
Total Physical Memory 12.0 GB
Available Physical Memory 4.05 GB
Total Virtual Memory 24.0 GB
Available Virtual Memory 15.7 GB
Page File Space 12.0 GB
Page File C:\pagefile.sys
Jeff
3 REPLIES 3
jdiala
As you can see on the properties on the lower right on picture 2 it shows the correct properties on the file.
The one you tag as "File as shown in the Folder?weird!" is the creation date.
Open explorer..
Right click the Name or any of the properties obove the files and click date modified.
That's should do the trick
in reply to: jdiala
JERI,
You are correct. wow so funny that it was so easy. I attach jpeg to see what I saw.
Jeff
jdiala
Windows 7 Home, Pro and Ultimate are all the same.
If you can see when you right click the "Name" and click "More".
There are still more properties that you can add to the file explorer.
