Far Clip Offset not available - to manually adjust?
Pshupe
Pshupe
Cannot manually adjust in the plan view and it is greyed out in the properties palette when the marker is selected and in the actual view.
Here's a good one.  It seems like an easy fix but it's not.  No View Template applied, not pinned, other Elevations in the same view I can adjust.  It's not just limited to this one Elevation marker.  It is also not Elevation type dependent.  It must be something to do with the actual view and not the Elevation marker
Any tips would be greatly appreciated.  Thanks.
Regards Peter
Pshupe
Inside the view, the properties palette shows the clip offset as available, but cannot adjust by typing a number in there and obviously cannot stretch the arrows in the referring view.  Here how the properties palette looks in the elevation view.  The far clipping is set to about 15', which is not far enough to actually see most of the building.  I need to stretch it, or manually modify the clip offset to see the building.
Thanks again for any tips.
Regards Peter.
Can you show the actual elevation view with the view crop region turned on?
Dependent View.
...or Duplicated View with Detailing
Pshupe
ding ding ding - We have a winner. Dependent View. It was staring me right in the face. Thank you.
Regards Peter.
mpaulyPXZ7H
Community Visitor
Community Visitor
This was happening to me. My view was independent, so that was not the problem. But I found the answer in my case: there was a scope box selected. I switched it to "none" and that brought back the pull arrows to adjust the section cut plane manually.
jiayi_huhu
Community Visitor
Community Visitor
Hi, please change 'Far Clipping' Type to 'Clip without Line', this mode allow you to change far clip offset. Please see attached.
