Family - with Dynamic array that expands with parameter dimensions
Short version -
I'm creating a massing Family with grips - to extend the width and length.
I'd like "model lines" to act as Grid lines to populate inside automatically on a defined dimension. (50' for example)
I'd like an array function to be associated to the overall lenght / width of the building and fill in the "model lines" while it stretches.
So - instead of telling the array to give me X equally spaced lines... I want the array to fill in a line with items at 50'.
This would be more like how a stair adds treads... the length of the stair may chance, but the treads maintain an equal spacing.
Avaris.
You can assign a parameter to your array.
Create a parameter that reads/sets the length of your item.
Create a parameter that sets the spacing.
Length/Spacing = 'parameter assigned to your array'
Corsten.Au
Hello
use inbuilt divide surface..
there are so many options once you choose pattern..
and many parameters ...
have a look..
Select the surface of mass.. Divide surface.... ( you dont need to reinvent this feature cause its implemented pretty well within massing )Select the surface of mass.. Divide surface.... ( you dont need to reinvent this feature cause its implemented pretty well within massing )
Various option using surface patternVarious option using surface pattern
and if you know how to assign 1. Instance Parameter ( Number, Integer ) or 2. Type Parameter, you can control those in the project once these Revit Mass families are loaded in the project...
cheers
Best luck
Corsten
Building Designer
bim1UHSLQ
Observer
Observer
Thank you all for your efforts to help - I think my original question wasn't specific enough. I've created an image to help.
First - my intent is to create a Site Plan component, that can be used for various projects of unknown sizes. Ranging from small to huge.
I may be referencing the wrong "tool" when I said Array.
When I grip the ends of the component and make it 300' wider, I want it to auto-populate new Grid lines inside, set at a designated spacing (50' for example).
Since the perimeter or the object will change - getting the model lines (grid lines) to show correctly once isn't what I'm looking for. I'm trying to program the object to respond correctly when manipulated.
Hope that helps clarify -
I think you are talking about something like this family. Load it into project and you'll have grips to size it dynamicaly in the x and y direction. "s" parameter (or grip) can control spacing. You can also make it so it has grips in 3D view as well.
Corsten.Au
Hi
Use a inbuilt Structure Beam system as a trick for 3D array / reference parametric model... reference image and screencast uploaded..
beam system.JPGbeam system - custom profile, associate to level, tilt at any angle...etc..
Corsten
Building Designer
I think everyone gives you a right answer, though they are different.  Attached is one approach.
