Family Void cutting Concept
ashiq_ansari
ashiq_ansari
I have a Ceiling Family which is Inplace Family type. I want to provide cut-out opening for Light Fixture over the ceiling. I used In-place Ceiling Category and tried to provide Void over the ceiling But I couldnt Pick Plane surface since its curved Ceiling. So I picked nearby flat surface as plane and tried to cut Its not working. But If I place Solid Extrusion Instead of Void Extrusion, If I change to solid Extrusion to Not in Scope Workset While its hidden the ceiling Cut was made. Is this proper way ? Or is it bug in this Revit 2022 ? Actually the solid extrusion is passing through the ceiling shouldnt show the Cut while hiding . But its showing Cut while its hidden ! I need Clarification for this
azad.Nanva
Use Mass in place instead of Void,then Join your mass with Ceiling.
mari.shimode
Hi @ashiq_ansari, did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Mari Shimode
RDAOU
@ashiq_ansari
The void wont cut if they are in two separate in place families. The void needs to be in the same in place family instance as the ceiling. ie:
  • start the In Place family
  • create the sweep for the ceiling,
  • create the void extrusion and cut the the above sweep
  • Finish the In Place family
