Family that thinks it's a central model
lpendergraft
Message 1 of 9
lpendergraft
Hello Everyone,
I'm having an issue with a family file that seems to think it's a central model. It will only let me save as and when I try to close it without saving it asks me if I want to synchronize with central...can families even be central models??
I created this family for use in a central model project. It does have shared parameters and one nested family. The nested family is one I created out of whole cloth. When I have tried to load this family into the central model it tells me that I'm trying to overwrite a family that isn't in the family or nested family. I'm at my wits end with this. Any body have any ideas?
Thanks!
Liz
Replies (8)
Message 2 of 9
I don't know what's going on either, but why don't you just Clipboard Copy/Paste contents into a brand new Family, and lose this weirdo Family?
Message 3 of 9
lpendergraft
@Anonymous good suggestion. We seem to be off and running now. Thanks!
Message 4 of 9
sthedens
That's all fine, but how does this even occur?
Message 5 of 9
lpendergraft
That's a great question, @sthedens and one that is way above my skill level. If you ever figure it out, please post it here!
Message 6 of 9
jose.villegasRQDWL
Hello everyone!
I came here looking for some help due to I had to deal with this problem few days ago (I wanted to stop recieving this alarm window every time I opened this family). And well, I can share with you some steps to end with this problem fortunately!
1. First, from the .rfa file, change its file extension to .rft.
2. Second, create a new family using the previous .rft file as template and save it now as a new family.
3. Finally, open this family from any project file (as you were about to edit family) and save it again as a new file.
Hope you find it useful!
Message 7 of 9
lpendergraft
Thanks @jose.villegasRQDWL! Appreciate the insight!
Message 8 of 9
david_seager
I'm a bit late to the party, but... I had this issue today, Liz.
I didn't want to use this family as a family template file (rft) because this then, essentially, locks down any of the elements therein.  For example, I'd then be unable to delete any unwanted reference planes should I feel the need to.  Didn't want to impose unnecessary restrictions on myself with this inherited family with which I'm not yet particularly familiar.
I also didn't want to simply copy/paste - because of the complex nature of the geometry and is reference planes / dimensions / parameters, which I'd be unable to copy / paste all together, needing to select some of those elements in plan view and some in elevation.
I found that simply loading the families into a project, opening them from within that project, and then doing a 'saveas - Family' seems to have done the trick.
Message 9 of 9
kdorbert
I'm just having the exact same issue, so weird.
