FAMILY SHOWING ON LEVELS THAT NOT HOSTED ON-REVIT 2019
jledgewood409
Message 1 of 10
jledgewood409
I HAVE AN ISSUE WHERE I HAVE FIRE EXTINGUISHER CABINET (SPECIALTY EQUIPMENT CATEGORY) PLACED THROUGH AND ON EVERY LEVEL. FOR SOME REASON THE FAMILIES ARE SHOWING UP ON LEVELS THEY ARE NOT HOSTED ON. MY VIEW RANGE IS SET FOR THE BOTTOM & VIEW DEPTH - ASSOCIATED LEVEL
Replies (9)
Message 2 of 10
zeulrick
If you wouldn't mind attaching the family, I will check it out. Don't worry, I won't use it. I have no need for fire extinguisher cabinets. 🙂
Message 3 of 10
jledgewood409
attached is the fire extinguisher family
Message 4 of 10
zeulrick
No attachment
Message 5 of 10
RobDraw
If there are model elements in the family that extend into the other levels it will show up in those levels.
Rob
Message 6 of 10
zeulrick
That's what I was going to look for...
Message 7 of 10
jledgewood409
sorry about that. let me try the attachment again
Message 8 of 10
zeulrick
It only shows up for me at the associated level. I would say double check the view depth. The family also doesn't have any geometry protruding above or below the level, so.... it should work fine.
Message 9 of 10
RobDraw
The family looks fine. The problem is probably in your view settings.
Rob
Message 10 of 10
Underlay in view?
