- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I had a question that I couldn't quite tell if it was answered before. I was looking at having a Family with a formula for a moving a group of objects to either left or right side then also having it so that each objects individual viability, within the group, can be toggled. So instead of having 6 check boxes for 3 objects on either side just having 4 check boxes where you only have to deselect the object to hide its visibility from either side and one check box to switch sides. I've never worked with formulas in revit before I assumed that this would be the formula-
"if(visibility,[not((Left Mounted),(Right Mounted ))],[or((Left Mounted),(Right Mounted))]"
-Or at least something similar. The formula was for a group of objects that had already been selected and grouped together and had [=not(Left Mounted)] as its formula on the Right Mounted visibility.
The other point would be that each object would need to be grouped, was there a way to group objects to have separate visibility settings and setting the group to have a specific yes/no option while the individual objects within it have their own individual. If you got this far I thank you for reading through my rambling, and any answer/comment you have.
-Thanks
