Family Parameter Error: The following is not a valid parameter
Ahmad_RagaeiJKJ4V
Ahmad_RagaeiJKJ4V
i'm trying to apply formula from shared parameter (Door Height) to shared parameter from nested family (Glass Panel Height) but i receive the attached error message.
Revit 2020
Any ideas about that ?
Ahmad_RagaeiJKJ4V
thanks its already solved, the problem was due to the presence of brackets in the name of the parameters.
HVAC-Novice
i assume you added the "(Shared)"to the parameter name for you to know what is a shared parameter vs a family parameter.
I do something similar, but I add "SHARED" to the front of the parameter name. No brackets.
And no, you have to recreate shared parameters, there is no re-naming. The name has to be what you need the first time.
Revit Version: R2026.2
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
