Family Parameter Conflicts
amirCKP
Message 1 of 24
amirCKP
Hi guys.
I had a problem with importing some families (Specialty Equipment) into project.
This error appear. I already remove the parameter mentioned, and try load back to the project, but still the error come up..
any idea? any solution?
tq
Replies (23)
Message 2 of 24
ennujozlagam
post your family so we can check. thanks
Message 3 of 24
amirCKP
Hi @ennujozlagam , attached is one of the families that got problem. Thank you
Message 4 of 24
ennujozlagam
i don't find any issues? thanks
Message 5 of 24
amirCKP
@ennujozlagam eh why you can load? haha.. is it you are using 2016 revit, and i use 2018, the issue on the revit 2018 version?
Message 6 of 24
ennujozlagam
try to save your family Revit 2018 and try to load again?thanks
Message 7 of 24
ennujozlagam
i dont find any issues in Revit 2018. try to install latest updates from autodesk and see if helps. thanks
Message 8 of 24
ennujozlagam
revit 2018.
Message 9 of 24
TripleM-Dev.net
The message indicates that there's a shared parameter in the project (or another family already in project) AND in the family with thesame GUID but with different datatype. Weight = Number AND Mass for identical GUID's
Looks like a manual edit of a Shared parameter file is used....!
Solution (I don't know which is the original?), delete the Weight parameter and create a new Weight parameter from the Revit UI. It can have the same name, but wouldn't advise it!
Either in the Family or in the project/other families....
We don't get the message because the other (Weight as number with identical GUID) doesn't exist in our project.
- Michel
Message 10 of 24
amirCKP
@ennujozlagam the issue is ssolved now. I got the idea when see your  videos. There is no issue if the family is load into new architecture project. It happen when i load to my project template. Now i have to find a way to remove the 'Weight' parameter in my project template. Thank you.
@TripleM-Dev.net yeah. The parameter clash with my project template. Do you know how to remove the parameter in the project instead of in the family? if i remove the parameter in the family, and load back to project, the error still happen.
Message 11 of 24
Do you see Weight when you open Project Parameter list? If so, delete it.
Message 12 of 24
amirCKP
@ToanDN nope. Its not there.
'Manage > Project Parameter' right?
Message 13 of 24
Edit the Parameter in the Family and change it from Shared Parameter to Family Parameter. If you need it to report in Schedules, then create a new Shared Parameter named "Specialty Equipment Weight" or whatever. Just not "Weight".
Message 14 of 24
TripleM-Dev.net
If the conflicing parameter "Weight" is not defined as Project parameter then it's in a existing family in the template.
It could be a not-placed family....
Create a new Project from the Project template, purge x-times until nothing further can be purged.
Now try loading the other family, if no message appears now, the parameter is in one of the purged families.
Other option is as @barthbradley mentions to change the parameter in the family with a new Parameter (I think you can replace te exiting parameter in the Family by another one, so no need to delete it first....)
- Michel
Message 15 of 24
amirCKP
@barthbradley i tried you suggestion but the error still happen.
Message 16 of 24
I don't see how that's possible.  Are you saying you are getting the exact same error message about conflicting Shared Parameters?
Message 17 of 24
So do you want to keep the Weight (Mass) or the Weight (number) parameter? One of them need to be replaced.
Message 18 of 24
TripleM-Dev.net
@amirCKP .
Maybe also share the concerning Project file (maybe purge/delete elements and save as compacted...if to large)?
Message 19 of 24
amirCKP
yes the same error appear even though I change the parameter name to other word.
Message 20 of 24
amirCKP
If can, I want to remove both of them. I didn't use that 'Weight' parameter at all.
