Family nested Voids in Legends/Schedules
Hi There,
I'm setting up Window/Door schedules the normal way, and a bunch of the window families have voids that are modelled to cut a sub sill out of a floor slab (for example) if required.
I've assigned a yes/no parameter to the void visibility which works well enough in the working drawings/model, but this parameter isn't an option in a Legend when you place a family, and thus the voids are showing up orange.
Is there any way at all to fix this? This seems like an oversight being that voids are not controllable at all with visiblity settings, which is a shame.
Anyone have any smart ideas? (Revit 2018.3 here)
All per the door on the right as shown below:Capture.JPG
Thanks!
Interesting. My Doors don't display uncut Voids in Legend.  Can you post one of your Door Families so I can see the difference?
Sure, here you go. The void is a nested general family within the Window family.
Turn off generic category for that legend view.
...or change your Visibility Settings for the Void Family
That did the trick. Thank you very much!
