family making radial array starting point and ending point fixed to a plan
Message 1 of 21
i am making islamic arc familly
when i change in arc radius lenght (1200)the angle of array  stay fixed (60°)  and stating point change
as image 2 show
what i want to do is to make starting point always fixed to the reffernce plan
the resault is to make arc like this with perametre chnging number of holes and diametre and arc radius
forgive my english i hope u undstand what i want ty for helping me
Replies (20)
Message 2 of 21
You can Align and Lock the starting Model Group in the Array to a Ref. Plane AFTER you create it.
Message 3 of 21
i do not find the lock botton can u show me how pls
Message 4 of 21
Yah, nix that.  It's not applicable here. Frankly, I don't understand the construction at all and it's going to require more time than I can give right now to figure it out.  Sorry.
Message 5 of 21
its ok thnks for ur try
Message 6 of 21
martijn_pater
Use an Adaptive Component family, see attached.
Message 7 of 21
FAIR59
I don't think you can align the last member of a radial array. You have to drive the array by the angle.
  • radial_array.PNGMake the angular dimension permanent and assign a label to the dimension [ array_angle ].
  • Make a (type) parameter for the distance between the midpoints of the circles. [ base_width ].
  • Formula for [ array_angle ] parameter :   acos(base_width / (2 * arcL))
Message 8 of 21
i use revit 2019
the attached files seems to be saved in 2020 or 2021 v  cant open it
any way to open it?
Message 9 of 21
acos(base_width / (2 * arcL))  ithink some thing is missing the angle stay allways fixed at 60
or may be i did some thing wrong
base_width is the same as arcL i think ?
Message 10 of 21
martijn_pater
It's a Revit 2020 file, I would have to build it for rvt2019 again... It uses devided path with repeated component (nested void). Not really sure if you can get it to work with a regular array if you want to be able to adjust the number of circles, the size and angle also... this way seems to work pretty good though...
Parametric arch (adaptive component)Parametric arch (adaptive component)
Message 11 of 21
this looks great .
can y build it in 2019 pls
and i am quite beginer in revit can u show me how to do this devided path with repeated component (nested void)
this will rly help me
Message 12 of 21
can u do a fast tuto for me pls
Message 13 of 21
martijn_pater
Here's a Revit 2019 version.
Message 14 of 21
FAIR59
the base -width can be different from the arc radius
Message 15 of 21
martijn_pater
Works good, however you can't input both number, angle & arc length. Not sure if you can do that without an adaptive family. But actually this is a little simpler and what you could add is the following to determine which method is used for calculation (and associate calculated parameters to the respective family dimensions). So you could input by angle aswell...
Calculation methodCalculation method
Message 16 of 21
even in the file u gave me of the adaptive family couldn't change angle always fixed in 60° do not know why
but the form works great
i was trying to remake it cause i am rly interested on how to do it more then results and i had  some difficulties i think it is just cause of  my beginner  lvl in revit .
would be great to make tutorial or at least suggest similar tutorials on YouTube
 and i had this problem when i put the family u sent in the wall
it does not make opening !!
Message 17 of 21
martijn_pater
Cut the wall with the family (under modify-->cut).
Message 18 of 21
works great 🤗 and as martijn.pater
 said we can add  could input by angle as well.
one little problem the border that handle the arc when we change in arc radius or base width we get deformation
some times arc is biger then the bored some times is so small
tried some ideals to fix it but i just couldn't any suggestions?
Message 19 of 21
ah ty forgot that 😁
Message 20 of 21
i tryed as hell making this arcs can u try to make them for me pls
