family is not loading into project
GoldenGateNetwork
GoldenGateNetwork
Good afternoon dear mentors.
I have a double glass door that I need for my project, it's not loading there, it's not appearing in the project list of doors, I changed the file name, it does not work, any suggestions please?
thank a lot
I am working on my NCARB towards my California Architect License,
if you think you can help me to complete my AXP, please let me know, I will really appreciate it. Thank you & Stay Wealthy, Happy, Healthy and Safe 🙂
Pedro Nel Ospina Hincapié
Bachelor in Architecture - Naval Architecture Student
Check the category of the family.
kostask_oionei
Can you share the family?
Probably, as @ToanDN says, the family category is not correct.
Open the family and check if the category "Doors" is selected.
If not, select it and reload the family to project.
If my post help you, please give a like.
If your question was answered please mark it with ACCEPT SOLUTION. This helps others to find answers...
Kostas Kouris
Architect Engineer, M.Sc., ACI, ACP
GoldenGateNetwork
@kostask_oionei , @ToanDN , thank you for your responses, please find attached the family, yes, category is doors. thanks a lot.
ralphdenhaan
Your family is a Metric Door - Curtain Wall (this family won't show up with the Door function). So in your case, you should generate a Curtain Wall and change the Panel to your Door family. Or create a new family, Metric Door for example  (this family will show up with the Door function in Revit).
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
kostask_oionei
@ralphdenhaanhas right.
If you want to use this exactly door, you can also create a new curtain wall type by Duplicate an Existing:
  • Check Automatically Embed
  • Select the door as Curtain Panel
  • Leave all the others parameters empty.
When you place this curtain wall let height unconnected and give the desired height and length.
Attention! you have to load the door from tab Insert -> Load Family (not from Door).
Kostas Kouris
