Family frame creation - paramatic structural beam + column
HAYDENRX9APH
Message 1 of 13
HAYDENRX9APH
Hi
I am having issues with a paramatic frame that I am making a family of. I want it to be adjustable in height, width and length. It mostly works however when I change from different types that I have set (i.e. different dimensions) it doesnt always seem to lock the dimensions and throws the constraint error.
I am not sure if this has to do with the way structural framing members and columns snap ? I might try doing it via a sweep but would prefer to do it this way.
Anyone able to suggest what i am missing? I have it all snapped to reference planes but just doesnt seem to want to stay. I think the error occurs when it goes from pod 5 to pod 4
Replies (12)
Message 2 of 13
Are you using Structural Framing and Column families in this family?  That would one explanation.
Just post the Family here.
...FWIW: Revit 2012 & Nested Structural Columns Workarounds (youtube.com)
Message 3 of 13
Are the nested beam, column families shared?  It is more liable if they are NOT structural column / framing families, but generic or line based families then category changed to structural.
Message 4 of 13
HAYDENRX9APH
i think i might have sorted it - think it was to do with disallowing beam joins at ends and providing more reference planes. now currently looks like this with reference planes each side evenly spaced
was previously like this which i think was the wrong way to do it
Message 5 of 13
Why are you using Structural Framing Families in this Family? Serious as a heart attack question.
Have you considered building this "Family" as an RVT that can be Loaded As Group into other RVTs?
Message 6 of 13
HAYDENRX9APH
mainly just due to it being a structural frame. yes have considered it although there is 40 or so to make and can all be inserted as families rather than models into a central model
Message 7 of 13
HAYDENRX9APH
open to other suggestions although ive chewed a fair bit of time into this already
Message 8 of 13
Well, I'd be happy to proffer advice if I understood what the deliverable was. That's precisely why I asked you why you are using Structural Framing and Column Families.
Message 9 of 13
HAYDENRX9APH
Gotcha - still having the issues unfortunately with the families breaking unfortunately.
I have put them all into 1 family with multiple types that have varying dimensions.
Wondering if it would be easier to just create a separate family for each type that way there is no issues in changing between types. my errors are coming from changing between types - might be the solution.
Message 10 of 13
Unfortunately, I don't "Gotcha" and given the lack of feedback and specifics from you, I don't think anyone here will be able to help you figure out why your Families are "breaking" -- whatever that means in your world.
Maybe you can answer this question: why not do what @ToanDN suggested?
Message 11 of 13
HAYDENRX9APH
Sure. When changing between the different family types it will break the constraints I have made (to the references) and break the frame. I have currently got it as a generic model family with structural framing member + structural column inserted. - what would be the new suggestion be for line based ? what family template do i use ?
Do you want me to send you the rfa to look
Thankyou
Message 12 of 13
Thankyou
Sure. Post the RFA.  Know how? As an Attachment in a Reply Post.
Message 13 of 13
@HAYDENRX9APH, post the rfa here to this thread. Hit Reply to this Post and then scroll down to Attachments and press Browse to locate the rfa on your Computer.
