Family Element Visibility Setting-3D View
dilistan.bozan
dilistan.bozan
Why 3D Views is not an option? How can i hide a component of family in 3D views in family settings? not in projects file. Thank you.
rxi.gg
Create a visibility parameter.
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
The best way to do this is by assigning the geometry that you want to hide in 3D to a Subcategory. This Subcategory can be turn on or off in the Project 3D View through VGOs.
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/Revit-C...
The reason I recommend this over what @rxi.gg is purposing, is because if you uncheck the Family's Visibility Parameter, it will hide the Geometry  in ALL Project Views.   Sounds like you just want to hide the geometry it in ONE View - not all.
