Family Colorless
Family Colorless
emersongonzalez1999
Message 1 of 15
Family Colorless
emersongonzalez1999
I download a family from Revit City it was a Truck Trailer its Colorful but when I load it to Revit is grayed out colorless. How can I make the truck appear as shown in Revit City?
Accepted solutions (4)
Replies (14)
Message 2 of 15
Manage > Object Styles > Imported Objects > Expand Imports in Family > Assign materials to the truck's layers
Message 3 of 15
syman2000
Is the material show up in realistic or shaded? If it is shaded, then they haven't add material to it. If it shows up in realistic, then they haven't make the graphic match the material. So anything you download from Revitcity require you to clean up before you can use it. Not everything shown in screenshot will appear when loaded into your project.
Message 4 of 15
emersongonzalez1999
I don't see anything related to the truck
Message 5 of 15
Just share the family here.
Message 6 of 15
emersongonzalez1999
Here is the files
Message 7 of 15
View Phase Filter set to "Show Complete"?
Message 8 of 15
emersongonzalez1999
Message 9 of 15
It's a Revit Specialty Equipment Family.  It is colorless. Paint it.
Message 10 of 15
emersongonzalez1999
Message 11 of 15
emersongonzalez1999
So I have to do manually ? like edit materials ?
Message 12 of 15
It is an actual Revit model, I am impressed.  You need to assign materials / paint surfaces 3d elements in the family.
Message 13 of 15
Just open the Family, create some colorful Materials, and then paint the Truck with those Materials using the Paint Tool.
Message 14 of 15
syman2000
You are better off with this family instead
https://www.revitcity.com/downloads.php?action=view&object_id=7696
Message 15 of 15
If you want to make a job of it, you could Paint with Instance-Type Material PARAMETERS.
See this link to learn more:
BIM Chapters: Revit Materials; Painting a Material Parameter
