Families' level option greyed out
Message 1 of 9
I am trying to change families' levels in my project but when cutting and pasting to a selected level, it still assigns a different level then the one I select. when trying to change the specific family's level in properties - the level selction is greyed out. How can I change the family's level?
Thank you!
Replies (8)
Message 2 of 9
What kind of family?
Message 3 of 9
Casework, Furniture, Plumbing fixtures
Message 4 of 9
Ilic.Andrej
Send them
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Message 5 of 9
Do you have the Edit Workplane available? You should. Sounds like the families have Workplane-Based enabled in them.
Message 6 of 9
What does it mean to have the work plane available? Thanks
Message 7 of 9
Select the family and check the Modify Tab options available to you (Contextual Tab). Do you have "Edit Work Plane"?
Message 8 of 9
These families are not work plane based, and can be placed anywhere.
Message 9 of 9
The behavior you are describing is consistent with "Work Plane Based" families. By this I mean: the "Work Plane-Based" checkbox is CHECKED in the family's properties (under "Other").  If this is not your case, then you should have access to its "Level" parameter in the project. But, what I understand you saying, is that this parameter is grayed out for each instance of it within your project. Is this correct?
