Failed to open file revit
majidhmod56
Message 1 of 8
majidhmod56
I have a Rivet project file, and when I open it, it asks me to upgrade the model from RFA (2009) to RFA (2023) and when upgrading it shows me 'Failed to open file revit', FYI, the project was running on RFA (2023), I want to restore it as soon as possible.
Thank you.
Majed Al-Otaibi - Architecture Student
Replies (7)
Message 2 of 8
Update to the latest Revit 2023 build.
Message 3 of 8
handjonathan
Hi @majidhmod56
Thanks a lot for posting your question to the forums!   Did you get a chance to try this when using the latest build, as @ToanDN suggests?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
Message 4 of 8
Simon_Weel
Try to upgrade in steps, if possible. Like opening the file in the oldest Revit version at your disposal and if that works ok, then upgrade in a newer version etc.
Message 5 of 8
majidhmod56
I did, nothing changed
Message 6 of 8
majidhmod56
The oldest version available is RFA 2020. The same thing happened. Can you try opening the file for me?
Message 7 of 8
majidhmod56
Message 8 of 8
Simon_Weel
Can you post the file?
