Face Based Void Can't be Hosted on Extrusion Base Face - Why ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am experiencing some Revit behaviour that I do not understand.
I have a face based void family that I often use.
I just found out that I can not host this face based void family to the 'base' face of an extrusion.
By 'base' face of extrusion I mean the face being the work plane of the extrusion, in which the profile of the extrusion was sketched.
I can host the void family on every other face of the extrusion just fine. Just not the base face.
Attached I have an example family. In it you find a simple cube extrusion, modeled from work plane Ref Level.
The family has a nested family in it called Gat Rond, which is the face based void family.
In the screenshot you can see the face based void family placed on some sides of the cube.
But I can not place it on the bottom face.
Do any of you understand why this happens and what is the logic behind it?
Many thanks in advance.
