Facade in revit 2019
P93mahapatra
P93mahapatra
How to make exterior facade like this in Revit 2019? anyone can explain to me in detail. It will be helpful.
Accepted solutions (4)
Replies (8)
mauricio_mssf
You can try to do with component model in place, or mass. Creating a cylinder extrusion and sculpting with voids.
If it is the same project there is also the possibility to import this already ready.
The other option would be to create something using Dynamo, adaptable families, but the programming would not be easy.
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
 Mauricio Santos Filho Arquiteto | BIM Manager
It's not going to be simple, and it is certainly not a process that can be "described" in a single forum post.  A book or a long video maybe.
I would start off looking at some of HyunWoo Kim's work.  I'm seeing an application here for Spirals and Helixes.
https://www.youtube.com/watch?v=u0IukRasY6M
http://plevit1.blogspot.com/2014/12/helix-again.html
https://www.youtube.com/user/PLEVIT1/videos
P93mahapatra
Yes i have the Sketch up file. how can i import that facade elements to revit.
P93mahapatra
how i can import the facade from sketch up to revit?
mauricio_mssf
You can clean the SketchUp file to leave only the facade and then import it into Revit.
1 - Import menu
2 - Import CAD
3 - Choose File Types to SkecthUp Files (*.skp Files).
Note: If the SketchUp file is well organized by layers, you can only pull the leyer with the elements of the facade. but I find it difficult to happen.
You can also follow the steps of this video, it shows how to insert elements as a family.
https://www.youtube.com/watch?v=mAGn_MHCzEQ
P93mahapatra
Yes I got this now in revit. How can change its material Colour in revit.
mauricio_mssf
Its good to know you got it.
As it is an imported object to configure the material, you needs to go in the Object Styles and change the material of the layers in imported Objects.
https://www.youtube.com/watch?v=36pBHvGFLgc
P93mahapatra
Thanks so much for your help. Do you know how can I make this facade from dynamo in revit. I want to learn more. I will glad If you can teach me.
