Extracting room name through a parameter
suganeshazhagesan
Observer Observer
Message 1 of 16
suganeshazhagesan
Observer
Observer
Hello Everyone
I am trying to model a face-based signage board that goes on doors or walls. It consists of a rectangular extrusion on which I have placed a 3d model text which will be controlled through an instance parameter. Coming to my doubt, I want that model text to change to the room name when placed on the door of that particular room. I tried using "Room Calculation Point" but I am not able to extract the room information from it, nor am I able to find any parameter which can achieve my intent.
Kindly help me or suggest any other ways through which it can be achieved.
Thank you. 😁
Replies (15)
Message 2 of 16
You will need Dynamo to do this.
Message 3 of 16
suganesh_matrix_a540
Can you tell how to go about it? the nodes to be used ?
Message 4 of 16
Yien_Chao
can you share the Revit family?
Message 5 of 16
Please find attached.
Message 6 of 16
Yien_Chao
i see.. i think the error is just the room calculation point. the one you shared is outside the room.
here another one with ajusted point.
Message 7 of 16
Thanks for the help but I think you didn't understand my problem.
I want the model text on the board to change automatically. It should change to the room name on which it is placed. eg. if i place the family on the door or wall of "Room-A" the text on the board should change to Room-A, if i place it on the door or wall of an another room say "Room-B" the text on the board should change to Room-B, it needs to be an instance parameter so that every time i place the board on different room the text should change to the name of that particular room. so i somehow want to extract the room name from the room tag using some means and apply it to the text on the signage board.
Thank you
Message 8 of 16
Yien_Chao
Ok i see.
You will need a Dynamo for that,  but i wouldn't work with you previous family because the room calculation point was outside room when placed on a door.
So try a dynamo with corrected family. If you need help, feel free to ask here.
Message 9 of 16
Sure ! I do need help with it ! If you can kindly do !
Thank you.
Message 10 of 16
Yien_Chao
Well start something first in Dynamo.
Try to get the parameter's value by name you are looking for and set to another parameter.
Message 11 of 16
Yien_Chao
ok, that was easy actually, but I didn't find how using only Dynamo.
here the simple Dynamo and a little bit of Python.
So the sign have the TEXT parameter with the room's number.
Message 12 of 16
wow! Thanks for taking your time and helping. Honestly, I don't know python 😅 I can understand the dynamo part of using the nodes but not the python programming part. Anyways i will give it a try !
Message 13 of 16
Also, how do I implement it? Do I have to just place the boards on all the rooms? or is there any method?
Can you share your script? and how do I use the room name instead of the room number?
Message 14 of 16
Yien_Chao
hi
just change the .ROOM_NUMBER for .ROOM_NAME in the code.
all built in parameters is also listed here : https://www.revitapidocs.com/2022/fb011c91-be7e-f737-28c7-3f1e1917a0e0.htm
of course you would need to place your family on the right doors, then execute the script.
you have everything needed to make it work. I wont comment any further.
Best
Message 15 of 16
Thanks a lot !
Message 16 of 16
Yien_Chao
@suganesh_matrix_a540  please mark it as a solution if it's the case.
