External Tools - Add-in Assembly Not Found
JasonLLINDNER
Message 1 of 8
JasonLLINDNER
On Friday I left the office and everything was fine but today when I was trying to check something in the model I kept getting the following popup warning when opening Revit. Any Ideas how to resolve? I tried the solution on this link  but it seems not even related. The folder they mentioned is already empty. I also checked the folder which is in the warning and it is also empty and cannot find the mentioned dll on any drive.
"Failed to initialize the add-in...does not exist" message appears when launching Revit | Revit 2020....
JasonLLINDNER_0-1634488781141.png JasonLLINDNER_1-1634488795812.png JasonLLINDNER_2-1634488853680.png
Replies (7)
Message 2 of 8
RDAOU
@JasonLLINDNER
All relate to Interoperability tools. Did you uninstall or update the addin in the past two days?
Also see following link - same topic as yours
 https://knowledge.autodesk.com/support/revit/troubleshooting/caas/sfdcarticles/sfdcarticles/Revit-Ex...
Message 3 of 8
JasonLLINDNER
I did not uninstall or update. Maybe the IT did in the office but I can still see the tab for Interoperability in Revit so it is for sure not installed.
Message 4 of 8
RDAOU
@JasonLLINDNER
Then most probably they updated without first removing the older version of the adding. Not knowing which version you've got, I would suggest that you do the following
  1. From windows control panel, Uninstall BIM Interoperability Tools for Revit (the images you posted say version 2020)
  2. Go to this directory C:\%USERPROFILE%\AppData\Roaming\Autodesk\Revit\Addins\2020
    Remove the following files
    BIT.10.ClassificationManager.addin
    BIT.20.ModelChecker.addin
    BIT.30.COBieExtension.addin
  3. Go to Autodesk Desktop App and install the latest available Addin listed there
Should fix it ...
Message 5 of 8
19fap2ar017
Community Visitor
Community Visitor
In my case I'm using Revit 2025 and unable to use environment plugin as Jason mention to remove (%USERPROFILE%\AppData\Roaming\Autodesk\Revit\Addins\2025) files , but my folder is empty
Message 6 of 8
19fap2ar017
Community Visitor
Community Visitor
how to resolve issue
Message 7 of 8
SameerAhamad
Community Visitor
Community Visitor
I am not able to export NWC files from Revit as Export to NWC option is missing in Export Tool
Message 8 of 8
bzakar1
Community Visitor
Community Visitor
i dont see the external tools
