Exterior Finishes
Exterior Finishes
Exterior Finishes
I am looking to acquire wood siding finishes for a building I'm working on. Any where I can get some?
aRcHiTeCt.JM
www.textures.com
www.pexels.com/search/texture/
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Viveka_CD
Hi @Anonymous
Welcome to the Autodesk Community! I see that you are visiting as a new memberSmiley Happy
Also, check out this video below: that describes Adding Different Colors to Material Elements, Clapboard Siding
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thank you,
Have you looked under your available Assets?
Thank you! This was helpful in finding other materials within the system, but how do I put these into circulation on my project?
Create a new material and assign an asset to it.
