Merging Split Toposurface
3 ANTWORTEN 3
Nachricht 1 von 4
woezme
857 Aufrufe, 3 Antworten
I have a quite large toposurface that I split.  I split this so when working with would work faster when editing.
On the topo that I split....I created a few subregions on it....Now, when I merged the topos back together...the
subregions disappear......How the do keep the subregions on the primary/secondary topos when merging I guess is the question?
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: woezme
Merge order.  Pick the surface with the SubRegions first and then the other surface to merge with.  Unless you mean  both surfaces are hosting SubRegions. In that case, I don't know how to prevent.
Nachricht 3 von 4
woezme
als Antwort auf: barthbradley
Yes...both surfaces will have a subregions
Nachricht 4 von 4
Select the sub-regions and copy clip before merging.  Paste aligned after merged the surfaces.
