Extending Walls on Sloped Floors
vmoustos
vmoustos
Hi. I'm new in Revit (using Revit 2020). I made a culvert model (using structural walls and floor) and trying to connect the four walls (red arrow and clue color on attached screen snip) with top floor but i receive the following message : Can't keep wall and target joined , any help ? Thank's a lot
martijn_pater
Probably has to do with those angles, you could share the file to have a look.
vmoustos
@martijn_pater thank you for helping me, here is the RVT file
martijn_pater
I think I'd just extend the walls a little to overlap with the (sloping) slabs and use join geometry.
vmoustos
@martijn_pater is it working for you ?
martijn_pater
Have a look at the attached.
vmoustos
@martijn_pater ...i see, thank you for help !
