Extending One Layer of Compound Horizontally in Plan View
Issue detailed in video.
Basically need to extend the brick layer further horizontally in plan view than the rest of the componund wall (i.e. insulation, avb, sheating,etc.) so far tried unlocking base of wall in section in the "edit types" window but to no avail.
It only works vertically.  Create parts and stretch the part instead.  Or make the wall longer and use a void to cut the other layers.
https://youtu.be/q7uv7_zHW-c
So you basically need to create parts for all of those different ending points?
joe_keogh
Hi @Anonymous
I think this is going to come down to the Wall Assembly definition.  can you post a screenshot of both the wall Assembly definitions so that I can replicate? I don't think I have it quite right.
Joe Keogh
Director | Design Technology + Innovation
www.viewlistic.com.au
There are two wall types, one is a brick face and the other is a metal panel face (currently shown as plywood, not important for this exercise to change material).
joe_keogh
Thanks @Anonymous
I think I have been able to achieve what you are after, using  the wall Def below:
Brick Clad Wall.PNGBrick Clad Wall.PNGTimber Clad Wall.PNGTimber Clad Wall.PNG
Please use Finish 2 for the Internal Finish.
if the Wall Join you get is not correct, you can use the Wall Join tool
Select the Wall join you want  to change, then click Next to cycle through the join configurations
Joe Keogh
Hey @Anonymous: I'll add here that Layer Function is key in Joining. I have "corrected" many join conditions by simply changing a wall layer's Function. Check out this AKN article for more information:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
