Extend Layers at End Of Wall
PhilvK
Advisor Advisor
Message 1 of 15
PhilvK
I've unlocked layers so the the wall finishes can extend to the base of the wall (orange arrows). How do I get the end of the wall highlighted in yellow to extend to the green line?
Replies (14)
Message 2 of 15
vitorbortoncello
unlock it too
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
Message 3 of 15
PhilvK
I tried that but can't figure hew. Cutting a section thru the end of the wall doesn't show anything.
Message 4 of 15
Does the wall originate from that lower level? If so, zero out the Base Extension values under the Wall's Instance Properties.
Message 5 of 15
PhilvK
Yes, that works for the end, but then the sides don't work. I want the wall to set on a concrete curb and the tile extend to the floor on the sides and end of the wall as in the sketch below.
Message 6 of 15
Ah, I see what you are doing now.  Offset the Wall from Level (offset=height of curb) and then enter the distance to drop the Base Extension.
Message 7 of 15
PhilvK
Did that too, but that brings the end up also!
Message 8 of 15
wait a minute. I think I  gave you the wrong instructions. Can you just post the file so I look at the Wall Assembly and see what's unlocked.
Message 9 of 15
PhilvK
File attached. Thank you for looking!
Message 10 of 15
Do not extend layers.  Lower the entire wall to the floor then join it with the concrete curb.
Message 11 of 15
This?
Message 12 of 15
PhilvK
Nice. Didn't know you could do that!
Message 13 of 15
Ah! I just understood your construction. You're wrapping a curb/stem on the ends with the wall's finish layers.  So basically, the curb/stem is an embedded wall.
https://help.autodesk.com/view/RVT/2024/ENU/?guid=GUID-68DB5265-BF43-45E3-AB8C-AC7813310548
...@ToanDN's a rock star as usual.  😉
Message 14 of 15
PhilvK
Embedding the curb appears to solve the end issue, but then the side layers can't be extended.
Message 15 of 15
Create Parts from Wall, Select the Core Part in Section View, activate Shape Handles and then drag the base up to the top of the curb.
