Exporting to DWG
Exporting to DWG
fluxusw
Exporting to DWG
fluxusw
Hello, I would like to know if there is any way to export an entire project to just one DWG file? I know I can take out each layer by layer, but I want it as one DWG file.
azad.Nanva
if i understand, you want to export all the Symbols Detail Items and all the sheet and 3d models in one Autocad file, No that is impossible because this is two different program with various ability.
but you can use the export to DWG for sheets and views and 3d model Export to DWG or DXF or DWF and whatever.
or
Corsten.Au
Hello
you can export each sheet individual CAD files ( with all elements ) without any xrefs.
Export and see those settings to pick all sheetsExport and see those settings to pick all sheetsfurther settings while saving to get rid of xrefs.further settings while saving to get rid of xrefs.
But if you are looking for just one CAD file which included all the Sheets, I feel that's not possible.
Cheers
Corsten
Building Designer
fluxusw
Yeah, that's my problem. I want to export it as one file, not multiple. Someone recommended an external add-on that can do it for me.
alan.johnson7YLND
If its the full 3D model you need in AutoCAD then you can export the 3D view and it will take just the 3D model.
alan.johnson7YLND
