Exporting Revit to AutoCAD
joseph_schwabNGN5U
joseph_schwabNGN5U
Problem:
Export from Revit to AutoCAD @ 22x34 sheet size.
Open AutoCAD sheet shows with a large white space at the top of the sheet.
Open Page Setup Manager and sheet size is in pixels set to publishtoweb PNG.pc3
Modify Layout 1,  Printer/Plotter Name is set to "publishtoweb PNG.pc3" instead of DWGtoPDF.pc3
Adjust settings to:
Printer/Plotter - Name: DWGtoPDF.pc3
Plot Area: Extents
Plot Offset: Center the Plot
Scale: 1:1
Click Preview and everything looks correct.
How can I prevent this behavior exporting from Revit? Is this a Revit default setting? Is this because there is no printer set by default?
I don't want to go through each drawing correcting the layouts.
joseph_schwabNGN5U
handjonathan
Glad you got all sorted @joseph_schwabNGN5U
Jonathan Hand
Technical Marketing Manager | Construction
