Exporting perspective section from Revit to Autocad
Recently I created a perspective section in Revit and now I need to work on it it Autocad. I put the 3D View with the perspective section on a sheet and exported. However, nothing from the file is visible in the Model in Autocad and cannot be worked with. Is there something I can do to fix that? Thank you!
I have the same problem but the response above does not seem to have a solution. Am I missing something?
Thanks!
Please check the Layout tabs from AutoCAD file once. Mostly exported sheets from Revit to dwg won't show up in Model Space.
Let me know if this works !
