Exporting issues from Revit to Autocad
nlevere
nlevere
When I export my Revit piping system, with colored pipes, to AutoCAD the colors do not save and everything in the AutoCAD file is white, not colored as I had it in the Revit file. Is there a way to fix this? I have tried to change the export settings in Revit to use the colors in view instead of by layer but I still cannot get the imported pipes to have the correct colors.
RDAOU
@nlevere
If you would post some screenshots of your Export settings and the view you are trying to export maybe one could make more suggestions...but with the limited info I would say
  1. Check the DWG export settings which you are using...and make sure you are using the appropriate export Layer export options (to be suitable for any overrides/filters/...etc applied to pipes category)
  2. Also in the layers export setting, check the color IDs defined for each category...or load a standard if you are not certain how to change
  3. Try exporting in Hidden Lines view instead of shaded
