Exporting cut paths from Revit for a hot-wire machine
charlesUYHXW
charlesUYHXW
I am trying to export cut path files from my assembly views to run on a hot-wire machine but cannot export a line path that is continuous. When I export the DWG, each line comes up as separate lines rather than one continuous line needed for the hot wire machine. We are running Visual CAD on the hot wire machine and would like to export the cut path from Revit without having to trace it in Visual CAD.
Do you know of any solutions to do this or potentially a plugin specific for producing cut paths directly from Revit.
L.Maas
Duplicate post. Other one see HERE
Louis
Please mention Revit version, especially when uploading Revit files.
