Exported DWF/PDF files are not matching
a_meteni
Advisor Advisor
a_meteni
When I export the attached “sample” RVT file to DWF,  the results are different from the PDF file!! This is 100+ sheets project and we usually review in DWF format and the final deliverable to client is PDF.  any thoughts are appreciated.
pendean
Community Legend
Community Legend
How is font handling addressed in your DWF driver?
Look up your PDF driver and match settings.
a_meteni
Thanks for the reply, But how to alter font handling settings from Revit export?
Using same print drivers with AutoCAD , the PDF/DWF outputs are matching without having to change anything.
Use a narrow font and set the width factor from 0.8  back to 1.
a_meteni
Thanks both of you. This is our first project with Revit 2019 and we've never had this issue with Revit 2016.
Seems like we'll need to update 2019 template accordingly Smiley Happy
loboarch
All text in 2017 was changed. If you are upgrading from 2016 (or updating/opening projects) or older, it is recommended you check all text outputs for these projects as things may have changed.
Read the top paragraph of this article for additional information.
http://help.autodesk.com/view/RVT/2017/ENU/?guid=GUID-F57326A0-BCE1-44D6-A5FE-3F084258EE28
Jeff Hanson
Principal Content Experience Designer
Revit Help |
