Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Export window IsExternal Revit 2023
10 REPLIES 10
Message 1 of 11
b.vanderhoeven
765 Views, 10 Replies
If you export a window to IFC it will get the value IsExturnal is False in the Pset_WindowCommon properyset. With Doors you can set this yourself, but not with windows. How can you get this right in the Revit way (I know that I can add a parameter IsExternal, I'm concerned about the difference with the parameter "function" with which you can set the IsExternal True or False in Doors)
10 REPLIES 10
Message 2 of 11
same here
Message 3 of 11
L.Maas
in reply to: robertovalentino
You can do this with a Parameter mapping Table
Create a txt file. Hereunder an example of what it should look like (spacing by TABs)
(Lines regarding Fire Rating are not relevant for you)
In Revit create a project parameter for windows (same name as in the txt file)
In Revit set IfcIsExternal to True or False for your windows
In the export to IFC load the parameter mapping table.
Result after export of the IFC
Louis
Please mention Revit version, especially when uploading Revit files.
Message 4 of 11
Simon_Weel
in reply to: b.vanderhoeven
Like @L.Maas says - add a Project Parameter. Also note there are quite a number of categories not having this IsExternal parameter, like Roof and Ceiling. So if you add the parameter for Windows, you might want to add it for those other categories as well. This is our list:
Message 5 of 11
L.Maas
in reply to: Simon_Weel
Then you also have to add to the the parameter mapping table to make sure that the IsExternal is coming in the right IFC (common) property set.
Louis
Message 6 of 11
@L.Maas
@Simon_Weel
thank you so much!
Message 7 of 11
Hi, i used another method and it worked for me,
I created a new Type parameter called IsExternal as a Yes/No parameter.
As shown under :
When Exporting the Ifc file it worked just fine.
I'm in Revit 2022.1.6
Message 8 of 11
b.vanderhoeven
in reply to: L.Maas
Message 9 of 11
b.vanderhoeven
Tags (1)
Message 10 of 11
b.vanderhoeven
in reply to: L.Maas
Tags (1)
Message 11 of 11
Tags (1)
