Export to IFC 4 - IfcRelConnectsElements - connection between elements
piotrpawelpiotrowski
Observer Observer
Observer
Observer
Does REVIT support export of connection between elements data into an IFC 4 format through IfcRelConnectsElements? I am looking for including this relationship in my IFC models:
https://standards.buildingsmart.org/IFC/DEV/IFC4_3/RC1/HTML/link/ifcrelconnectselements.htm
If so, how is this supported?
Many thanks for any hints point me in the right direction!
L.Maas
I am not sure if this is implemented, but doubt it. You could try the forums of IFC addin on github and see if they have implemented something https://github.com/Autodesk/revit-ifc.
Louis
Please mention Revit version, especially when uploading Revit files.
Observer
Observer
Many thanks for the hint - I will check with the github forum and report back if I get a response.
piotr.piotrowskiSL6ML
At the moment the IfcRelConnectsElements is not supported by Revit. Some interesting ideas for workarounds where further discussed at: https://github.com/Autodesk/revit-ifc/issues/553
