I am trying to export a project from revit as a gbXML file. When I click export it fails and tells me to check the project information. I believe the problem is my conceptual mass but I am unsure how to fix it.
This error displays when you attempt to export to gbXML and the building model does not contain any room-bounding elements in the specified phase.
Error: Can’t create any energy analysis surfaces. There are no room bounding elements defined in the current phase. Please check the Project Information settings.
Solution: Do the following:
check this link https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
Ahmed Muharram, B.Sc, AEE, ACI, ACP
BIM Manager
