Export to DWG, text corruption
Hi all! Im having problem with text exporting into DWG. issue is that final DWG have corrupted text entities. Its happend that text is breaking, separating and changing text text styles.
In attached file is example of my texts ( up revit, down dwg )
Is there some way how to solve this problem?
Viveka_CD
Hi @Anonymous
Which version of Revit/ AutoCAD are you using?  Can you confirm if you have the latest updates installed for your Revit and AutoCAD versions? Please check your Desktop App for updates.
Can you share a file to test and the font/ windows version you are using?
Hi, im using Revit 2017 but this is happening also on 2017.2, 2018 and 2019. With autocad it is same as is 2007 or 2018.
I tried to use different font type but doesnt help. As i notice, separating text is happend only with certain letters as á, é, ó, ô, ú, í, ý, ĺ, ŕ,
In attachment is rvt and dwg file with text content
Thank you!
