Message 1 of 13
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm using Revit 2016/2018. I have an issue with exporting small objects (about 50 mm - Structural Columns, Walls, Generic models, Curtain Wall Mullions, etc...). When I export to DWG view with a view scale of 1:100, everything is ok. All objects appear and nothing is missing. When I export the same the view but this time with scale 1:200 or higher, some elements went missing. Probably in the export process Revit omits small object.
Do you have any solution or workaround, for example by changing some undocumented system variables in Revit.ini?
Jiri
