Export to DWG problems – Revit 2019
GA-LT
GA-LT
Hi, during export to cad format  when option Export Rooms and Areas as Polylines is marked all  linked dwg are not visible in exported cad.  Why is that?
LT
ennujozlagam
see screenshot below. thanks
GA-LT
Hi, your solutions helps a little bit but to bind manually all the references files causes some problems so better not to check this options "Export rooms, spaces and areas as polylines". It’s wired  because Revit is so called WYSIWYG  but unfortunately can surprise with the results "for an unknown reason" 🙂
