Export to dwg in STB Plot style
4 REPLIES 4
dtBAGKQ
647 Views, 4 Replies
dtBAGKQ
How do you get Revit to export to DWG using the STB Plot style?
It has been the standard in AutoCAD since 2005 so it should be the default export format from Revit.
4 REPLIES 4
in reply to: dtBAGKQ
Unfortunately, you can't.
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/screencast/Main/Details/c60e4d6a-2...
You would have to use CONVERTCTB to convert the drawings to use STB.
dtBAGKQ
dtBAGKQ
I found this solution in a post from 2012 and just couldn't belive there hasn't been any progress since.
Thank you for your help.
My solution to this is rather simple.
- We start a new drawing from a STB template, configured to our specification.
- Insert the exportet file from Revit.
So the export setup can be configured to fit with our STB template, even though it's in CTB.
But I still think the default setting of the Revit export should be STB, since AutoCAD is geared more towards that.
Vuxvix
Vuxvix
Hi!
I am using AutoCad and Revit 2024. Currently AutoCad 2024 no longer supports PCP files. Is there any other way than installing an older version of Autocad?
Hi!
