Export to cad and zip
yes_and_no
1,202 次查看
4 条回复
1 条消息(共 5 条)
yes_and_no
Realized I didn't have the use for autocad for about 5 years now, so I deleted it from my work from home pc.  When export multiple Rv17 sheets to cad for consultants, I see the zip option is no longer there.
Is it a result of removing cad ?
If not, how wd I get it back, or did I miss something?
0 个赞
1,203 次查看
4 条回复
回复 (4)
2 条消息(共 5 条)
What zip option?  Export to DWG normally to a folder and compress the folder to a zip file outside of Revit.
0 个赞
3 条消息(共 5 条)
yes_and_no
Somehow I have it in one mouse click before.
0 个赞
4 条消息(共 5 条)
RobDraw
One click? Doubt it.
At a minimum, you need to click on File, Export, CAD formats and select the set before executing.
Rob
0 个赞
5 条消息(共 5 条)
You are perhaps confused between Export to DWG in Revit and eTransmit in AutoCAD.
0 个赞
