Export to AutoCAD different colour
anaszok12
Message 1 of 8
anaszok12
Hi everyone,
I encountered a problem where the exported dwg (filled region in this case) produced different colour, not as in my export settings. It supposed to export the filled region in colour 8 instead of colour 27
Cheers,
Anas
Replies (7)
Message 2 of 8
Mohamed.Hesham.afifi
Hi @anaszok12  ,
if your project contain a linked project and the display setting of the link (basics tab in rvt link display settings) is set to be "by host view" so the link is treated as an override .To ensure that colors and other graphic display settings are preserved in the exported file, on the Modify DWG/DXF Export Setup dialog (Layers tab), select "Export all properties BYLAYER, but do not export overrides
you can check this it might helps :
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2017/EN...
Ok that's it 🙂 , if you find this helpful , kindly accept as solution
Message 3 of 8
anaszok12
Hi  Mohamed.Hesham.afifi
that helped me a bit. However, I specified the filled region to be in colour 250 and the output is still in colour 7 (white).3.JPG
Cheers,
Anas
Message 4 of 8
Hi @anaszok12  ,
I don't know further what's the problem indeed , but can you attach your revit model here to see where is the problem till someone else come and help you
Regards !
Message 5 of 8
Viveka_CD
Hi @anaszok12
Please share your Revit and AutoCAD files and a journal to help test further on our end.
Also, specify the versions you use and confirm if you have the latest updates installed.
Message 6 of 8
anaszok12
Here are the files as requested
Currently I'm using Revit 2018.3 and AutoCAD 2018
Message 7 of 8
ennujozlagam
hello, try to change your filled region colour to this value please see attached and see if helps. thanks
Message 8 of 8
anaszok12
There are two methods i have tried-
    • Change the colour settings to -specified in view(true colour - RGB values). It does gave me what I wanted except it does not match with my firm autocad settings. It creates a new colour corresponds to RGB instead of index colour.11.PNG
    • edit manually in autocad
