Export Thin Lines
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
We recently just purchased a shiny new Total Station, and the exporting the drawings so they could be loaded onto the tablet was all new to me. I had to export from Revit into a dwg (sounds like the tablet only uses dwg files. Revit files are too much for a tablet to handle). When we were on the jobsite getting trained on how to use the total station some the walls on the tablet had really fat lines and made it tough to tell if we were snapping to wall stud or the edge of the sheetrock; sometimes it worked if we zoomed in really close, other times it didn't. When I draw in Revit I always have thin lines mode turned on, so I didn't even think about it when I exported it. I've never really messed with line weights before, so how do I make it so my dwg export has thin lines? I drew in the underground plumbing, but I drew it on the architectural print. Does it make a difference that it was a dwg floor plan to begin with that I linked into Revit, then exported from Revit with the plumbing?
I don't export from Revit very much, usually I just print to pdf. Also, apparently, when exported, the linked dwg file didn't export with my plumbing drawing, it still needed to be x-referenced.
Is there a good method/process/workflow for exporting from Revit to dwg for a total station tablet?
Revit lives in the land of perfect and doesn't understand what construction is.
