Export Revit to autocad line scale problem
ayman_tamimi
ayman_tamimi
Hello guys, hope you are all good, I am working on a project now, and sometimes I need to export my Revit file into dwg, so I found a problem that all my nonsolid lines such as hidden lines or dotted lines are solid when it exported to dwg, later on, I found that I have to change the linetype scale from the AutoCAD manually for each layer from these line types! , is there any solution to prevent this from happening!? and thank you
syman2000
When you export, I would choose scaled linetype definitions. That way when you open AutoCAD, you don't need to take extra step to change the configuration to match the linetype. If you choose the PSLTSCALE = 1 or 0, you have to go into AutoCAD and change the annotative scale to make the linetype show up.
