I am trying to model the backing on this spiral stair:
I tried a model-in-place Sweep and chose the 3-D edge along one of the sides. However, you can see that it does not align so the other side:
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
My recommendation is use floor or roof
Modify sub elements and set two points to the underside of the spiral stair
As a result you will get finish at the bottom
