Export Revit Model with Linked Models to IFC
cgaum
cgaum
Community Visitor
Community Visitor
I have host Revit file with linked Revit folders - I need to export to an IFC format file with all links, but these are not showing in the exported file.
matt.arsenault_adsk
Federated IFC Export was released as a feature with Revit 2024. You can locate that export option under: Export IFC > Additional Content > Linked Files.
handjonathan
Hi @cgaum
Thanks a lot for posting your question to the forums!   Has the solution suggested by @matt.arsenault_adsk helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
