Sucede que de un momento a otro la visualizacion en 3d se pueden ver los elementos aun en color, pero se ven las aristas que no deberían verse a menos que uno lo desee, en mi caso no deseo ver las aristas "internas", no me deja trabajar!!!!
It happens that from one moment to the next the 3d visualization you can see the elements even in color, but you see the edges that should not be seen unless you want to, in my case I don't want to see the "internal" edges, it doesn't let me work!!!
In that image you can see the way the elements look, you can see the internal edges and I don't want the visualization in that way, someone to help me please!! I've been there for several days and I can't find the solution!!
Occasionally, I encounter a similar issue. What has been effective for me is opening a non-3D view, closing all tabs, and then reopening the 3D view.
I think maybe there is something to do with graphic card or memory
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
Autodesk Certified Professional
