The add on works great, except for one problem. As you can see on the photo, the model drapes onto the terrain. How do I rectify this problem so that the model is level?
The model should be level.
There is no real control in regards to the model placement exactly on the Google Earth topography. To match a site in Google Earth, Globe Link is somewhat limited. The best way for the model to be at the correct elevation when exporting is to physically move the model up in Revit [temporarily, to compensate for the difference in where you would like it placed], and then export.
Thank you,
Ryan,
I think the question is:
Why does the Revit model "tilt" with the slope from terrain inside GE?
Sketchup models do NOT do this. We have to convert our Revit models to SU and then bring into GE
because of this problem.
I think there is something wrong with the Revit plug-in which causes this. Please pass on to the Factory.
This needs fixing and has been neglected for a long time. It causes us to NOT USE Revit's Google Eath Connector
feature.
cheers
"Sketchup models do NOT do this. We have to convert our Revit models to SU and then bring into GE"
Correct. There is a rather major bug in google export from revit. You can fix it, but you need to hand-edit the xml files to fix things. it's a while since I have done it, but the error is that the Z values in Revit are exported with the 'relative' flag (ie, it will work for a perfectly flat site), whereas the Z values really should be Absolute (ABS)
It takes quite some time to hand-edit 100,000 or so points, as a find-replace search or some PERL scripting can help you.
Alternatively, make sure you only build on flat sites. This may be easier 😛
Have you found a direct fix for this (other than editing the xml file or exporting to another program before Google Earth)? I am experiencing the same thing – publishing the model in Google Earth is somehow causing the geometry to warp/drape over the topography. Also, any chance you understand why this happens or at what point during the import/export process? Thanks!
