Export or add coordinates in schedules
christin.verhaeghe5LUKU
I would like to add coordinates in different schedules but that seems missing. Does someone knows to do it.
Coordinates of what?
What I meant is the coordinates of an object X,Y,Z in the selected coordinate system. So in Belgium is that the Lambert system.
L.Maas
You would need to add parameters to the elements and then fill that with the relevant data.
You could use a Dynamo script to fill that data automatically (assuming you have set up the coordintes in your project).
Louis
Please mention Revit version, especially when uploading Revit files.
OK to do this via Dynamo but this should be possible as a default inside Revit
constantin.stroescu
I can show my method on doing this.
I use a Generic Model Adaptive Family that can be included into Schedule.
The following example shows how to make a Table of Coordinates in order to be used on Site tracing:
https://forums.autodesk.com/t5/revit-architecture-forum/how-to-create-point-with-coordinates-info-in...
Constantin Stroescu
