Hi.
I understand you want to export family parameters to Excel, translate the data and import it back into the Revit file.
You can use a free third party add-in to achieve that. Download DiRootsOne and use the SheetLink tool to achieve that.
DiRootsOne - 8 Productivity Tools | Revit | Autodesk App Store
After installing
- Create a Schedule of the Category and add all the Fields (parameters) needing to be changed.
- Launch SheetLink and switch to the Schedules tab
- Select the Schedule created in step 1 and Export to Excel.
- Edit the file in Excel as needed. Save and close. (make sure not to edit hidden data, rename or move columns)
- Follow the instructions in this video to translate the data. (The BIMLink tool (paid) is a bit more advanced than SheetLink, but for your needs the SheetLink will work perfectly)
https://youtu.be/ArSgS-AZXEI?t=153
In SheetLink, having the schedule selected, Click Import and select the translated file.
Let me know if this works
BIMologist
- Nauman Mysorewala
Did you find this post
helpful? Feel free to like this post.
Did your question get successfully answered? Then click
on the ACCEPT SOLUTION button.
