Export dwg with text and layer issue
minhkhuev3
Observer Observer
Message 1 of 1
minhkhuev3
Observer
Observer
I have exported dwf from revit model and i met some problem that i can't solve any way,
#1: With exported text: if i choose Preserve Editability. Some text in dwg is not as they are in revit model. We come from Viet Nam so we have to use Vietnamese in our drawing so we can't choose Preserve Visual Fidelity because our text will be broken up and it's unacceptable. How to make Exported text looks like it does in Revit and Paragraphs are NOT broken up.
#2 With exported layer color: i choose Use Index color and set color by layer, with same objects the color are different from each other. For example in some place wall cut are white but in other place wall cut are colored by layer while all wall cut are in same layer (set by user)
How to fix it?
Thank in advanceexported text in cad fileexported text in cad file
text in revittext in revit
Wall cut are in same layer but the colors are different in exported fileWall cut are in same layer but the colors are different in exported file
Replies (0)
